nkelesh
Nov 29, 2013Aspirant
4.2.25 & 10.9 Time Machine Capacity?
I just upgraded my Ultra 6 Plus to 4.2.25 and it looks like 10.9 is ignoring the capacity limit that I define for backups. On the Mac side, Time Machine is reporting all available space on the ReadyN...
nkelesh
Dec 01, 2013Aspirant
HowieG wrote: Thanks for this. I'm rather reluctant to use SSH as I'm not yet very familiar with Linux etc. However it's good to know the cause is understood. I presume you've tested and confirmed the fix works in practice?
Are other NAS manufacturers also affected as they were with the previous issue?
Yes, it fixed my problem.
I'm only familiar with Synology and I do believe they use the same technique of setting a user quota for Time Machine, however I can't say if they are having the same problem as well since I don't have one on hand.
