k_a_b
Jan 10, 2013Follower
4 disk NV+ won't boot after a Power Cut
ust over a week ago 1 one my NV+ (B unit) after a power cut failed to find its shares, on further investigation, all disks but no 3 are showing 0GB size, also where it was set to X-Raid before in the...
Jan 10, 2013Guru - Experienced User
Keep in mind that sharing the UPS via the network requires that you also use it to protect your lan (switches/router on the connection path)
mdgm wrote: Regarding UPS units APC is a good brand. Most APC units which have a USB port (must have a USB port, serial-to-USB is incompatible) will work.
Connect the power of your NAS units and your router/switch to the UPS. Also connect a USB cable between one of the NAS units and the UPS. Then share it across your network with the other NAS
