geojay
Jun 26, 2018Guide
4GB seagate drive for RN204
Following a drive failure, I wanted to get a new drive for a RN204. I was going for a 4GB and historically choose Seagate. The list at https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-Li...
Jun 27, 2018Guru - Experienced User
Marc_V wrote:
ST4000DM000 and ST4000DM004 are both Desktop drives
Barracuda ("DM") drives have a rather poor track record in RAID arrays, though I believe the 3 TB models were much worse than the others.
I always recommend NAS-purposed or Enterprise Class drives, and no longer recommend any desktop models for ReadyNAS. NAS-purposed drives are about the same price as desktop, and have features like TLER that are intended for RAID.
So I'd recommend getting a 4 TB Seagate Ironwolf drive, or the WDC equivalent (WD40EFRX). If you want faster RPM, go with the Ironwolf Pro, the WDC Red Pro, or perhaps WDC Gold
geojay
Jun 27, 2018Guide
Presumably, to stay at the same price point as the 4 TB ST4000DM004, a 3 TB Seagate Ironwolf (ST3000VN007) would be OK?
- Marc_VJun 27, 2018NETGEAR Employee Retired
Hi geojay
ironwolf ST3000VN007 is compatible and should be better with the Desktop drives, however since you have 4TB drives it won't be a good idea for a replacement. I would suggest going with the 4TB or higher capacity models that is designed for NAS like what StephenB mentioned
e.g. Seagate ST4000VN000, WD WD40EFRX, or HGST HUS724040ALE640
Regards
- StephenBJun 27, 2018Guru - Experienced User
When replacing a drive with XRAID, you always need to use
- the same size as the drive you are removing or
- a drive that is at least as large as the biggest drive in the system.
Replacing a 4 TB drive with a 3 TB model simply won't work.
- geojayJun 27, 2018Guide
Hi Stephen,
As per https://community.netgear.com/t5/Using-your-ReadyNAS/Dead-volume-on-ReadyNAS-204/m-p/1595245/highlight/true#M146843 I'm not replacing a 4TB drive, I'm replacing a 2GB and the volume (across the three original disks) is dead so I'm essentially starting from scratch.
Thanks
Marc_V wrote:
Hi geojay
Regards
Hi Marc,
I don't have 4GB drives, this is to replace a failed 2TB drive. As per my post at https://community.netgear.com/t5/Using-your-ReadyNAS/Dead-volume-on-ReadyNAS-204/m-p/1595245/highlight/true#M146843 I had three 2TB drives, two of which failed. One will be replaced under warranty and I'm replacing the other drive myself which is the purpose of this post.
Hi @geojay
Oops
sorry i forgotIf you previously have a 2TB drive then replacing it with a 3TB drive would be an upgrade. It would be better if you replace all 2TB drives with the same size as the replacement. This is to utilize the 3TB drive replacement. So the Ironwolf model you mentioned earlier is a good fit :)
Regards
