geojay
Jun 26, 2018Guide
4GB seagate drive for RN204
Following a drive failure, I wanted to get a new drive for a RN204. I was going for a 4GB and historically choose Seagate. The list at https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-Li...
geojay
Jun 27, 2018Guide
StephenB wrote:
Marc_V wrote:
ST4000DM000 and ST4000DM004 are both Desktop drives
Barracuda ("DM") drives have a rather poor track record in RAID arrays, though I believe the 3 TB models were much worse than the others.
I always recommend NAS-purposed or Enterprise Class drives, and no longer recommend any desktop models for ReadyNAS. NAS-purposed drives are about the same price as desktop, and have features like TLER that are intended for RAID.
So I'd recommend getting a 4 TB Seagate Ironwolf drive, or the WDC equivalent (WD40EFRX). If you want faster RPM, go with the Ironwolf Pro, the WDC Red Pro, or perhaps WDC Gold
Hi Stephen,
To be clear, I'm replacing a 2 TB Seagate Desktop drive and the replacement won't be inserted into an existing array (that died, as per the original post), I'll be starting from scratch with no volumes set up on the NAS. I was originally going for a 4 TB Barracuda drive as a replacement but following your advice, I'll go for a Ironwolf instead. The 4 TB Ironwolf is more expensive than the 4TB Barracuda but the 3GB Ironwolf is about the same (and is still larger than the failed 2 TB drive) so I was asking if the 3 TB Ironwolf is OK, especially considering your comment about the 3 TB drives being worse which I assume only applied to the Barracuda range.
I hope that makes sense!
Thanks again for your advice :)
