btaroli
Jan 14, 2017Prodigy
6.6.1 Scrub Hammers CPU
And when I say hammers, I mean it runs with -1 prio and causes 6-8 kernel worker threads each vying to consume 100% of CPU. So rabid is this consumption that all other background processes, including...
btaroli
Jul 12, 2017Prodigy
In the case of PLEX and DVBLink it's definitely the transcoding that was most affected. Recordings and other operations seemed ok.
Time Machine (really the AFP file service) would get so starved for cycles that my backup would corrupt and get flagged to be replaced (as TM is want to do) whenever it attempted to run during a scrub.
I fully appreciate the de ription of the scrub processes you present here, but I can tell you that until I forced them into idle with ionice I was having exactly the problems described. And once having done it the behaviors stopped.
I was rather hope to let the scrub finish, since this value has never been scrubbed fully, and it's 5 days in now at about 55%. But I'm happy to restart the process to compare the ioprio on the breads as reported and detail/verify the outcome of the tweaks. Been through a few iterations during this run. But I am in a state now where things are humming along nicely, even if the scrub is taking a while -- which is fine by me.
The affect on the other processes (whether it's CPU, IO, or a combination of both) is real and extremely annoying, however. So something does need adjustment here.
I do observed on Fedora that btrfs scrub behaves as described on the btrfs wiki and your description. The base process is in ioprio B4, as well as one of the threads, the thread doing the effective IO is in idle. Course on this system effective CPU utilization is under 40% (four threads) and iowait is almost nil. Debian is of course quite different in how kernel threads operate, but this is what I see on fedora.
I'll restart the scrub on the NAS later tonight and see what I see there to compare. Not totally apples and apples, but I think it's odd how btrfs stopped getting in the way of other services until it was ionice'd directly.
I'll report back once I've had a chance to observe it again without manual adjustments.
- SkywalkerJul 12, 2017NETGEAR Expert
It's worth noting that the resources consumed by btrfs scrub can vary widely depending on the files it's scrubbing at the time. Very fragmented files will result in a lot more I/O wait time, and more CPU consumption. Also, a ReadyNAS volume scrub also includes a MD RAID scrub, which adds to the I/O load. MD is generally pretty good at yielding to other I/O consumers, but it's still a minimum 30MB/sec used for that plus the CPU usage for parity calculation.
- Michael_OzJul 12, 2017Luminary
Still on 6.7.4.
Started scrub.
Three threads as described above, main process & two threads (shown with H command to htop)
PPID PID USER IO IORR IOWR IO PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command 1 29003 root 41462 41462 0 B3 19 -1 32180 200 16 S 5.6 0.0 0:26.28 `- btrfs scrub start /N316AR6 1 29005 root 0 0 0 B3 19 -1 32180 200 16 S 0.0 0.0 0:00.03 | `- btrfs 1 29004 root 41462 41462 0 id 19 -1 32180 200 16 D 5.6 0.0 0:26.26 | `- btrfsI'm reading that as the IO/IORR/IOWR & CPU usage is accounted for in the main process too, rather than both doing I/O & CPU.
Note active thread is idle iopriority, nice -1 (as most things spawned from readynas seem to inherit -1).
However, sort by CPU, (K command to show kernal threads), everything with CPU > 0.
PPID PID USER IO IORR IOWR IO PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command 2 29066 root 0 0 0 B4 20 0 0 0 0 R 39.9 0.0 3:52.37 kworker/u8:10 2 29043 root 0 0 0 B4 20 0 0 0 0 R 38.2 0.0 4:47.15 kworker/u8:9 2 28656 root 0 0 0 B4 20 0 0 0 0 R 37.0 0.0 4:37.22 kworker/u8:2 2 28793 root 0 0 0 B4 20 0 0 0 0 R 37.0 0.0 4:42.18 kworker/u8:3 2 30086 root 0 0 0 B4 20 0 0 0 0 R 35.8 0.0 1:05.82 kworker/u8:14 2 28903 root 57.2 57.2 0 B4 20 0 0 0 0 S 33.4 0.0 4:37.18 kworker/u8:8 2 28071 root 0 0 0 B4 20 0 0 0 0 R 33.4 0.0 4:27.62 kworker/u8:0 2 29095 root 19.2 19.2 0 B4 20 0 0 0 0 R 31.6 0.0 1:44.06 kworker/u8:13 2 28902 root 0 0 0 B4 20 0 0 0 0 R 31.0 0.0 4:56.74 kworker/u8:7 2 1515 root 0 0 0 B4 17 -1 0 0 0 R 25.6 0.0 35h04:21 md127_raid6 2 27507 root 0 0 0 B4 20 0 0 0 0 R 17.9 0.0 4:31.39 kworker/u8:1 2 29067 root 0 0 0 B4 20 0 0 0 0 R 17.9 0.0 4:30.13 kworker/u8:11 1 29003 root 45490 45490 0 B3 19 -1 32180 200 16 S 6.0 0.0 1:12.96 btrfs scrub start /N316AR6 1 29004 root 45517 45517 0 id 19 -1 32180 200 16 D 6.0 0.0 1:12.87 btrfs 2 29001 root 0 0 0 ?? 39 19 0 0 0 R 3.0 0.0 2:22.40 md127_resync 28517 28522 root 0 0 0 B4 20 0 29460 3688 3004 R 3.0 0.2 0:56.68 htop 2 1402 root 0 0 0 B0 0 -20 0 0 0 S 1.8 0.0 0:54.53 kworker/1:1H 2 1401 root 0 0 0 B0 0 -20 0 0 0 S 1.2 0.0 0:50.00 kworker/0:1H 2 1359 root 0 0 0 B0 0 -20 0 0 0 S 0.6 0.0 3:29.12 kworker/2:1H 2 1389 root 0 0 0 B0 0 -20 0 0 0 S 0.6 0.0 3:34.20 kworker/3:1H 2 7 root 0 0 0 B4 20 0 0 0 0 R 0.6 0.0 4:10.65 rcu_sched 1 3703 nut 0 0 0 B4 20 0 17240 1296 932 S 0.6 0.1 1:31.42 /lib/nut/usbhid-ups -a UPSNote all the CPU chewed up by kworker threads, Nice 0, doing little IO. (kworker IO increased later, similar numbers as above, but more threads doing IO)
btaroli's media processes (infering from the above iopriority B7/B6 - I don't know what they are doing) will have lesser nice values, and be CPU constrained. Those at B4 will have Nice 0, round-robin with all those kworker's, so ~1/12th CPU (?5/17th?).
How changing the iopriority of the other two threads can change this I can't fathom ATM.
Perhaps media threads with a 'interactive' workload should run nice -1 for now.
Longer term there should be a gap between current -1 processes (readynas etc) and default worker thread priority (currently 0 ), so intermidiate priority things can fit in the middle??
I'll repeat this on 6.7.5 when I get around to it, I'm currently juggling 10TB disks upgrading...nothing happens fast...
p.s. I run encryption, so CPU may be higher in my case. (?)
