RoyalEF1's avatar
RoyalEF1
6.9.3 X-RAID horizontal expansion-does it only work with same size now?
I've had these readyNAS running for about 8 years now.  A year or two ago I moved them to 6.xxx. I have 3x10TB disks and just inserted a 4TB that is going unused.  I can format it, but it won't ad...
  • StephenB's avatar
    Jun 22, 2019
    RoyalEF1 wrote:
    Prior to 6.x mixing smaller or larger disks was inconsequential--XRaid2 added them in.
    No, it didn't.  4.2.x firmware had the same restriction (plus a few more).  It's actually fundamental to the way mdadm works.
    For example, if you start with 4x4 TB, the system has a single RAID group of (also 4x4 TB RAID-5).  If you add two 10 TB drives,  that RAID group is enlarged to 6x4TB RAID-5 (20 TB).  At this point you are only using 4 TB of the new drives.  So the system creates a 2x6TB RAID-1 group that uses the rest of the space - and then concatenates both RAID groups into one 26 TB volume.
    But if you start with 3x10 TB drives, the system would have a single 3x10 TB RAID-5 group.  If you insert a 4 TB drive, the system would have split that RAID group into 2x4 TB RAID-5 + 3x6 TB RAID-5 in order to add it to the volume.  It can't do that, so the new disk isn't added.
    So ReadyNAS XRAID will add new RAID groups to handle newly inserted larger disks.  But they won't split an existing RAID group - and that is what would be needed in order to handle insertion of a smaller disk.
    Since whatever path you took before worked, you must not have ever added a disk that required the NAS to split an existing RAID group.
    RoyalEF1 wrote:
    Now... My 2nd ReadyNAS (same model, 6.9.2) started with 2x6TB + 2x4TB disks.
    I replaced a 6TB & a 4TB with two 10TB.  So it is now 2x10Tb, 1x6TB, 1x4TB.
    That works fine, since the added disks are larger.
    Initially you had two RAID groups: 4x4TB RAID-5 + 2x2TB RAID-1.  After you upgraded you had  4x4 TB RAID-5 + 3x2TB RAID-5 + 2x4TB RAID-1.  So this upgrade path didn't require splitting any RAID groups that were in the array.
    RoyalEF1 wrote:
    However, I did realize that 6.x says XRAID... where 4.x called it X-RAID2..
    That's just marketing.  Originally the v1 sparc products had XRAID, but it didn't handle mixed drive sizes at all.  When they introduced the 4.2.x systems they added support for mixed drive sizes, and rebranded it as XRAID2.  When they introduced OS-6, they decided to drop the 2, and went back to the original XRAID branding.
ProSupport for Business
