farrerdave
Nov 15, 2012Aspirant
Accidentally Removed Unit ReadyNAS Remote APP
Hello, I used to be able to see my ReadyNAS Duo unit listed on the 'ReadyNAS Remote' tab of the iPhone App but I accidentally deleted this through the edit button. Now I can no longer see the unit and...
farrerdave
Nov 16, 2012Aspirant
Thanks I finally got this to work. I managed to solve the issue by uninstalling the app turning off my ReadyNAS duo. Turning it back on and then reinstalling the app. If you accidentally delete through the edit setting like me (I think you are just telling the app to forget the unit by doing that) it will only reappear after you reboot the device and reinstall the app.
Following that I found it is important to set up the FTP service to allow anonymous login. I had no luck logging in with my user accounts for some reason.
