Gjermex
Dec 03, 2017Aspirant
Adding a drive to the Readnas Duo V2.
Hi friends! I've had my ReadyNAS Duo v2 for quite some time, and I've been quite satisfied with the unit. It's been running as my Time Machine Backup drive, as well as network storage to be used ...
Dec 03, 2017Guru - Experienced User
You needed to put the system into flexraid mode when you installed the 8 TB disk. That's described here (pages 25-28): http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
Gjermex
Thanks for your reply.
JBOD is one of my formatting options when putting the system into flexraid mode
I've formatted both disks to Flexraid - JBOD.
I did this so that I can control what goes on each separate disk.
The 3TB disk is a few years old, so I don't want to store anything valuable on it.
- StephenBDec 03, 2017Guru - Experienced User
Ok. I guess the next step is to try and create a second volume when the erase completes.
- GjermexDec 03, 2017Aspirant
I can't seem to figure out how to create a new volume.
It seems to me that the unit identified the second disk when I hot-inserted it, but I'm unsure how to actually create a second volume, either in the Web UI, or in Raidar.
- GjermexDec 04, 2017Aspirant
The erase process is completed.
I hot-inserted the disk, and once again both the web ui and Raidar identifies the disk, and gives me the green lights.
Still no Volume D.
I've tried taking out the disk and putting it back in, with the unit running. This gives the same result.
After that, I tried rebooting the device with both disks inserted, but I still only have one volume.
Here are some photos to document my system status.Web UI identifies the hot-inserted diskBoth disks seem okRaidar gives me the green lights
