harryrichardfoe
May 02, 2019Guide
Admin account locked out - constantly
Hello, I have recently upgraded to 6.10 on my Readynas 212 and have been constantly hampered by not being able to log into the admin account from Chrome. This occurs 90% of the time stating that too ...
May 02, 2019Guru - Experienced User
I haven't seen any configuration settings for the lockout and It is only supposed to last for 5 minutes.
FWIW, I haven't been locked out either with Chrome or Firefox, and I have been accessing the NAS admin page pretty frequently. HTTP admin is disabled, so my log ons are all using HTTPS.
harryrichardfoe
May 02, 2019Guide
After gaining access, I did what I wanted, changed the password and then logged out. After an hour I tried to gain access the Nas. Same problem, admin account is locked out.
- SandsharkMay 02, 2019Sensei
It sounds like something on your network is trying to connect with the wrong password. Do you have a device you configured to auto login with the admin password that is now sending the wrong one periodically?
- StephenBMay 03, 2019Guru - Experienced User
I was wondering that too. It fits the symptoms.
- harryrichardfoeMay 03, 2019Guide
Yes, I will check some of my ultilities for the Nas.
I also have a legacy Readynas Ultra 2 plus running 6.10 that wasn't showing the same symptoms. I thought it a bit strange.
Thanks for the tips.
- Apr 16, 2020Anonymous
