nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
chirpa
Dec 08, 2008Luminary
Maybe something like this:
Bonjour Mounter will mount your AFP or SMB share points silently in the background.
Add Bonjour Mounter to your login items to mount your share points on login without that annoying finder window popping up.
It will also automatically mount appearing bonjour enabled servers when they become available.
If you have the Bonjour discovery service enabled on the NAS, that should in theory mount when the NAS is discovered.
