nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
starg4ze
Jan 27, 2009Aspirant
One BIG advantage of Bonjour Mount is that the mounts remounts if you for example reboot the nas, or getting a network dip that makes you drop the connection to the NAS.
I also used the "login-items" before, but when I found Bonjour Mount...I don't any more. Excelent piece of software!
/SG
/SG
