nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
niaolong
Feb 05, 2009Aspirant
Please see my reply above. Download automountmaker (http://mac.softpedia.com/get/System-Uti ... aker.shtml), install and start it. Select "new" to make a new script with what you want to launch. You will need one script for every share you want to launch. Save the scripts and then drag them into you start-up items in System Preferences/Accounts. Next time you start up your Mac, the shares should be launched automatically.
