nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
rcarr6502
Jun 12, 2009Tutor
After a lot of trial-and-error, I discovered that if you're going to use the System Preferences->Users->Login Items method to automount your shares, make sure you automount your private home share (or other non-guest-login shares) BEFORE you automount other shares. Otherwise, your private home share (or non-guest-login shares) won't mount and will give you an error -6602 on any attempt to mount, until you unmount all shares and start over.
This is true in OSX 10.5. I don't know if it's true in other revs.
