nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
fixmacs
Jul 15, 2009Guide
This is very easy to do. Don't need AppleScripts or any third-party applications.
1) Mount the NAS share manually
2) Go to System Preferences in the Apple Menu
3) Select Accounts
4) Select Login Items
5) Drag and drop the icons for the ReadyNAS shares from the desktop to the Login Items window
6) Quit System Preferences
You're done. The NAS shares will automount at start-up.
3) Select Accounts
