nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
fixmacs
Jul 18, 2009Guide
An MBA is a master's of business administration.
This seems like it is as you suggest--a problem with the MacBook Pro, but not the ReadyNAS.
This is a work-around (not an elegant fix). Create a folder on the desktop. Drag the nine(! why would you have nine shares? oh well) shares into the folder. Then, drag the folder into the Dock. Clicking once on the folder in the Dock will connect to all shares.
