nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
fixmacs
Jul 18, 2009Guide
The simplest solution is to turn off OS sleep. Allow the display to go to sleep but not the computer. The screen uses most of the energy. Set computer to Never in the Energy Saver.
As for the folder of aliases, if you put the folder left of the separator, in the application section of the Dock, the volumes should automount. If not, you can always do Cmd-A (select all), then double-click on any single alias.
Or....use Folder Actions (right click: More: Enable Folder Actions) and use the Mount Network Volume action...
Good luck.
Good luck.
