nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
Earl0101
Jul 31, 2009Aspirant
... Should note that my configuration assigns a fixed Ethernet IP address instead of DHCP. This is defined in "Interfaces" below "Network" selection in "ReadyNAS Frontview" under Ethernet Tab.
Perhaps stating the obvious here but if you don't use a fixed IP address don't use it for the 'NAS_Location' variable.
Earl
Earl
