nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
dmglover
Aug 07, 2009Aspirant
You are correct. I had the same problem with 10.5.6. Apple fixed it with 10.5.7 and now with 10.5.8 I have the finder window opening with my shares at start-up. I have no idea how to get this fixed myself other than do not mount at login....
