nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
CharlesLaCour
Sep 22, 2009Aspirant
I am running OS X 10.6 Snow Leopard and I was using autofs to automount shares.
I created the directory /afp
I added a line to the /etc/auto_master file like this:
Created the file /etc/auto_afp with something like:
You can reboot or restart the autofs by running the command:
At this point I was able to use /afp/backup to access the backup share or /afp/mac to access the mac share.
The "-ghost" on the line in the /etc/auto_master file basically puts the "backup" and "mac" directory in the /afp directory regardless of if the share is mounted or not. Without it you would no see the backup and mac directories until you accessed them and they were mounted which would make it imposable to browse to the directory.
This was working but now that I am testing it again it is not functioning.
/afp auto_afp -ghost
backup -fstype=afp afp://mynas/backup
mac -fstype=afp afp://mynas/mac
sudo automount -vc
