nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
KillerBob
Jul 31, 2011Aspirant
And when you go into finder, connect to the NAS (is there an AFP version?), and into a share, try to check "Get info" on that share. The server should read "afp://XXX (AFP)._afpovertcp.local/YYY" The format should read "AppleShare". Does it?
KB
KB
