nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
BeatCrazy
Aug 01, 2011Aspirant
sphardy wrote:
Instead you need to select the mounted share itself from the finder sidebar and then do "Get Info". Alternatively double click on the share and when the shares files/folders are shown in the right finder pane, but without selecting any file/folder, do a "Get Info"
:x I tried all the steps you described, still not getting any info from "Get Info".
sphardy wrote: mount -t afp afp://mynas.local/backup /mnt/backup
I confirmed the above does work for me, though note my NAS is still running 4.2.17
Oh for two!
I tried each way (making sure to include the .local) with both IP, and NAS name, and only get:
mount: realpath /mnt: No such file or directory
This is really frustrating, because I can absolutely manually mount the share, and it shows as (AFP) in Finder.
And I did do a sudo mkdir /Share before I tried these.
