nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
BeatCrazy
Aug 02, 2011Aspirant
Thank you for taking the time to explain that. I was not using the terms consistently, and now have a better understanding of each.
My error was in never creating the /mnt parent folder mount point. For some reason, I assumed that already existed, as part of the OS.
I think I can get this to work now. I appreciate your examples above.
Should I remove the /Music parent that I created by mistake?
