nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
BeatCrazy
Aug 08, 2011Aspirant
Good tips, thank you.
Luckily I'm the only user. I don't think I can handle any more hiccups for a while.
Yes, mounting this way can either be fast or slow. I've seen it mount immediately, but other times take over a minute after the desktop appears. Too bad I couldn't get the Command prompt method to work, but this gets me the same goal with minimal hassle.
