nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
BeatCrazy
Oct 26, 2011Aspirant
Singularity wrote: Did you manage to sort your problem out.
To auto mount discs or shares you do not need any form of scripting or any other 3rd party software. You can auto mount a disc or share by specifying them as a Login item in your 'User & Groups' of your preferences panel. You could actually specify different shares for different users if required. It is a simple drag and drop routine.
This is by far the easiest way and no need for complicated routines.
Cheers
Yes, I got this sorted out. I used the method you're describing. Works fine, every time.
