nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
victorhortalive
Nov 27, 2011Aspirant
What is the situation of this automount wrt using a Win7 Bootcamp partition in Parallels ?
If I automount a NAS share under User Login alternatives (with CIFS) and then start Parallels where the same share is mapped to a Win7 drive, is the share already mounted before Parallels starts ? Or does is it get mounted twice ?
Reason I ask is that if I let my MBA sleep with a Parallels Bootcamp already running it seems to take a long time for NAS shares to be available in Win7. Specifically, if I open Outlook and look for emails (my email store is on the mapped NAS share), then I am likely to get a hung programme for 30 secs or so. If I can mount the share before I open Outlook then maybe this is avoided.
