nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
sphardy1
Nov 27, 2011Apprentice
I'm a little confused by your terminology - Parallels enables you to run Windows as a VM, whereas Bootcamp is Apple technology to allow Windows to be run natively on Mac hardware
Either way, Windows will mount the shares separately to OSX unless there is a mode in Parallels to make already mapped shares available to the Windows installation (and you are using that)
