nd
Dec 08, 2008Aspirant
AFP auto mount on ReadyNAS startup (OSX 10.5.5)
Hi there Is it possible to get some of the shares automatically mounted, when the NAS ist started up? Or even better as soon as the ReadyNas is visible in the Finder? This would also allow me to conn...
sphardy1
Nov 27, 2011Apprentice
The mode you are using is running Windows as a VM, though using the physical installation installed using Bootcamp (rather than from a disk image for example). As such it will be accessing shares directly, not via OSX, and so mounting in OSX first should not make any difference.
FYI: I have noticed that my macs do tend to take longer to mount CIFS based shares vs AFP - never figured why, but I'm meaning maybe 10-15 seconds mac, not 30 secs as you describe.
