pcautschi
Dec 01, 2015Aspirant
After upgrading to firmware 6.4.1 my external usb hdd with btrfs is not recognized any more
Hi,
after upgrading to firmware 6.4.1 my external usb hdd with btrfs filesystem no longer gets recognized and mounted on my RN104.
Until now it worked without any problem and i do not want to change the filesystem.
Mounting by commandline works without any problem but is there any quick advice how i can get the harddrive automounted as with 6.4.0 ?
Best regards
Christian
- mdgm-ntgrNETGEAR Employee Retired
Can you connect your USB disk to any PC. Make sure you do not format it. Then do a safe remove from the PC and connect it up to your NAS again and see if it then works.
- SkywalkerNETGEAR Expert
Hmm, I thought btrfs wasn't working on USB drives in 6.4.0. Anyway, there is no way to get it to automount on 6.4.1. It will be supported in the next release, but that won't be coming very soon.
- TomFormanAspirant
I get the same behaviour but the USB drive appears to be formatted as FAT32. At least when I plug it in to my laptop, it reports as FAT32.
Connecting this drive to my RN104 does nothing. There is no log saying anything is connected and the UI doesn't report a thing
Can I mount this via command line?
