TigerRob
Nov 16, 2016Tutor
All Shares appear to be missing [ReadyNAS Ultra 2; Radiator 4.2.28]
Some weeks ago I (possibly stupidly) ignored a reported filesystem consistency check failure. Have had the check pass successfully since. Today I discovered that I can no longer connect to any o...
TigerRob
Nov 17, 2016Tutor
StephenB - yes I am running Crashplan. From other threads it appears there might be some Crashplan directories that grow (and should be moved onto a data partition). Pointers for cleaning up the crashplan installation and moving the appropriate directory would be much appreciated.
TigerRob
Nov 17, 2016Tutor
StephenB Found this thread https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/987406#M10801
I suspect that gives me enough pointers - will investigate later.
- TigerRobNov 18, 2016Tutor
Thank you all for your help (esp. StephenB for the mention of crashplan)
3.5GB in /usr/local/crashplan/iupgrade ...
Stopped crashplan, moved that directory off to the data partition and softlinked to it, rebooted, and I appear to be back in business.
- StephenBNov 19, 2016Guru - Experienced User
You will need to get the upgrade to 4.8 to work, otherwise the problem will come back. I had to create a .wgetrc file to disable the certificate check to get the upgrade to complete.
- TigerRobNov 20, 2016Tutor
StephenB thanks for the heads up. This thread is now well OT, but ...
Crashplan apparently didn't like me soft-linking the upgrade directory over to the data partition, so I re-instated a real (but empty) upgrade directory.
Then saw what you meant by the wget problem, and so added a check_certificate=off directive to /etc/wgetrc. That solved the download issue, and the upgrade proceeded. LOkking at the logs it didn't complete correctly, but appears that the failure was somewhere towards the end of the upgrade script where it was attempting to upgrade teh GUI, and we don't need that ..
But my 4.8.0 install fails with errors in the engine_errors.log - it appears to be this issue https://www.reddit.com/r/synology/comments/550806/best_crashplan_docker_image/d87beo9/ and modifying FULL_CP, as suggested gets me to a different error, which appears to be a 32- vs. 64-bit libstdc++ error:
java.lang.UnsatisfiedLinkError: libstdc++.so.6: wrong ELF class: ELFCLASS32
More research needed to find out how to get a 64-bit version installed and get Crashplan to find it ...
