TigerRob
Nov 16, 2016Tutor
All Shares appear to be missing [ReadyNAS Ultra 2; Radiator 4.2.28]
Some weeks ago I (possibly stupidly) ignored a reported filesystem consistency check failure. Have had the check pass successfully since. Today I discovered that I can no longer connect to any o...
TigerRob
Nov 22, 2016Tutor
Not sure why I'm having trouble posting the details to this thread. I'm now removing all formatting (although I wasn;t using much before) and hope it'll get through this time.
So, I have a 64-bit Java installation. On investigation the crashplan install script uses "uname -m" to determine which JVM to install, and so on a ReadyNAS will pick a 64-bit bundled JVM. On upgrade the upgrade scripts looks at the installed JVM (whereever JAVACOMMON points) to determine whether to use a 32- or 64-bit version. So, if you installed a 32-bit Java before Crashplan insisted on using the bundled JVM then your upgrades will have stuck to a 32-bit version. For me it weas keeping a 64-bit version, as that was what was bundled when I did my original install.
I simply replaced /usr/local/crashplan/jre with the 32-bit JVM downl;oaded from code42 (see upgrade.properties for the URL) and I have a happy, working Crashplan again.
Thanks all,
Rob.
Nov 22, 2016Guru - Experienced User
This explains why some users end up with 32 JVMs (with Crashplan working) while others ended up with 64-bit. Thanks for sharing.
