eclark
Apr 20, 2018Aspirant
Amazon Drive not turning on
I've been using Amazon Drive to back up my ReadyNas for over a year. I checked Amazon to make sure that everything was backed up, but saw that the backups stopped a few weeks ago. So, I went on my ad...
owensj
Jun 21, 2018Aspirant
I am having the exact same issue. One of my NAS syncs perfectly and the other won't let me turn Amazon Drive on. Surely it is something simple I am missing.
yoban
Jul 06, 2018Apprentice
I too have identical symptoms as the OP. I am able to enable onedrive cloud option but amazon drive on/off switch will not turn on. I have not looked at the logs and can do so in a few days, but would think I should not “lock up” like this. I am running OS 6.9.3.
Any thoughts?
Any thoughts?
- yobanJul 06, 2018ApprenticeHi there I have pulled down my logs and have found the following in the file "fvamazon.log" which repeat..... -- Logs begin at Sat 2018-07-07 01:43:58 NZST, end at Sat 2018-07-07 11:59:47 NZST. -- Jul 07 11:55:33 Honbu systemd[1]: Started Amazon Cloud Drive client for ReadyNAS. Jul 07 11:55:33 Honbu fvamazon[27972]: Not provisioned Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Main process exited, code=exited, status=255/n/a Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Unit entered failed state. Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Failed with result 'exit-code'. Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Service hold-off time over, scheduling restart. Jul 07 11:55:33 Honbu systemd[1]: Stopped Amazon Cloud Drive client for ReadyNAS. Jul 07 11:55:33 Honbu systemd[1]: Started Amazon Cloud Drive client for ReadyNAS. Jul 07 11:55:33 Honbu fvamazon[27975]: Not provisioned Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Main process exited, code=exited, status=255/n/a Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Unit entered failed state. Jul 07 11:55:33 Honbu systemd[1]: fvamazon.service: Failed with result 'exit-code'. Jul 07 11:55:34 Honbu systemd[1]: fvamazon.service: Service hold-off time over, scheduling restart. Jul 07 11:55:34 Honbu systemd[1]: Stopped Amazon Cloud Drive client for ReadyNAS. Jul 07 11:55:34 Honbu systemd[1]: Started Amazon Cloud Drive client for ReadyNAS. Jul 07 11:55:34 Honbu fvamazon[27978]: Not provisioned Jul 07 11:55:34 Honbu systemd[1]: fvamazon.service: Main process exited, code=exited, status=255/n/a Jul 07 11:55:34 Honbu systemd[1]: fvamazon.service: Unit entered failed state. Jul 07 11:55:34 Honbu systemd[1]: fvamazon.service: Failed with result 'exit-code'. Jul 07 11:55:34 Honbu systemd[1]: fvamazon.service: Service hold-off time over, scheduling restart. Jul 07 11:55:34 Honbu systemd[1]: Stopped Amazon Cloud Drive client for ReadyNAS. Jul 07 11:55:34 Honbu systemd[1]: Started Amazon Cloud Drive client for ReadyNAS. Any ideas on what is happening? I have rebooted NAS and also cleared my connection in ACD.
- JohnCM_SJul 11, 2018NETGEAR Employee Retired
Hi yoban,
Can you send the complete system logs of the NAS? You can check this link on how you can send it.
- yobanJul 13, 2018Apprentice
JohnCM_S wrote:
Hi yoban,
Hi JohnCM_S,
Thanks very much for that - logs emailed and have put attn: JohnCM_S in the subject. Hopefully they will identify the issue, like a service that is not running.
Look forward to your response.
Cheers.
- JohnCM_SJul 25, 2018NETGEAR Employee Retired
Hi yoban,
This issue should be able to be fixed through back end. You may contact NETGEAR Support so they can assist you with this.
- jbattistaAug 01, 2018Tutor
I am also having the same problem with Amazon Drive switch not turning on and not allowing me to connect. I am using ReadyNAS v6.9.3
I have tried 2 different browswer's: Safari and Firefox. I have cleared the cache which looked initially like something was going to happen but only to fail to turn on again.
Anyone have any success enabling Amazon Drive feature?
