hunterbagwell
Sep 02, 2018Aspirant
Amazon Drive not turning on
I am having the same issue of the Amazon Drive will not turn on as in the discussion:
https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Amazon-Drive-not-turning-on/m-p/1555839
Marc_V
Sep 03, 2018NETGEAR Employee Retired
Welcome to the Community!
Have you tried changing your Network settings as mentioned in the post? You can do that by going to the Network Tab and clicking on the Cog icon and set a static DNS server like google DNS (8.8.8.8) and your router address.
Make sure you have this check marks as well under the cloud tab
You may also want to try leaving Amazon cloud and toggle he service on and off.
Hope this helps!
Regards
hunterbagwell
Sep 03, 2018Aspirant
I use 8.8.88 and 8.8.4.4 as my default DNS since I bought the NAS units. Unfortunately, that does not allow me to turn the service on.
I did not understand the last statement "You may also want to try leaving Amazon cloud and toggle he service on and off." I have removed permissions for the NAS in Amazon hoping it would reprompt for permissions when I turned the Amazon service in the NAS on. It does not help. All the other services in the NAS (Google, Microsoft, etc...) allow me to turn the service on in the NAS and begins the process. Not Amazon.
- Marc_VSep 03, 2018NETGEAR Employee Retired
Apologies on the last statement, what I meant was to toggle the service forgot that it can't be turned on.
Kindly download the latest logs and since you have done OS Reinstall already it may need back end access to remove the configuration/settings of the Amazon service.
Were you able to get in contact with Support? You can go to my.netgear.com and login to create a case.
If you can send me a link to your logs kindly PM that to me. e.g Dropbox or Google drive.
Regards
