Sandshark
Nov 17, 2021Sensei
Anyone running Win11 with a legacy NAS?
Has anyone tried accessing a legacy (OS 4.1.x, 4.2.x, or 5.x) NAS with a Windows 11 preview? It would be good to know if the current work-arounds have been cut off and whether there are any new ones...
Nov 17, 2021Guru - Experienced User
Sandshark wrote:
Has anyone tried accessing a legacy (OS 4.1.x, 4.2.x, or 5.x) NAS with a Windows 11 preview? It would be good to know if the current work-arounds have been cut off and whether there are any new ones required. Users of those old systems will want to know before they decide on whether to upgrade to Win11 or not.
The only computer on which I would be willing to try it doesn't meet the Win11 minimum requirements. I've seen some stuff on installing it as a VM, so I may try that if noboady else has anything to report.
I do have one PC running Win11 - I'll try to test with my 4.1.16 NV+ tomorrow, and report back.
Nov 18, 2021Guru - Experienced User
I can access Frontview with both Chrome and Edge (clicking through the self-assigned cert warning, as usual).
I can also access shares after enabling the CIFS/SMB1 client. This works using both the NAS IP address and the hostname, though I suspect the hostname will continue to be a bit hit-or-miss.
I can't test 4.2.x or 5.3.x, since I don't have NAS running either of those.
- SandsharkNov 18, 2021Sensei
That being the oldest of the OSes, I suspect the others will also work fine. Good to know they left in the ability to turn on SMB1. Is yours a Home or Pro version? Just want to be sure turning on SMB1 is possible in the Home version. Even if I get it on a VM, I only have keys for Pro.
- StephenBNov 18, 2021Guru - Experienced User
This was using Win11 Home.
Using Win11 Pro on a virtual machine, I can confirm that a NAS running OS 4.2.31 or 5.3.13 is reachable via Edge or Chrome (user or admin GUI) and via SMB with once SMB1 is enabled. Network discovery actually seems to be working better than in Win10.
Last question regarding compatibility with ReadyNAS is if ReadyCloud works on it. Neither I nor StephenB use ReadyCloud, so has anyone tried?
