pwarlike
Aug 22, 2013Aspirant
Apply factory reset without total data erase
Hello I have ready nas pro 6 with 6 discs: 1-2: Volume c in Raid 1 3-4: Volume d in Raid 1 5-6: Volume e in Raid 1 I don't know if this is possible: A) I remove discs 3,4,5 & 6 B) Back...
Aug 22, 2013Guru - Experienced User
I've never tried it. I wouldn't do it w/o a backup!
If you do attempt it, save the configuration pre-reset, and restore it post-reset. As usual, don't hot-insert when you reinstall 3-6,as the NAS will wipe the disks if you do that.
