pwarlike
Aug 22, 2013Aspirant
Apply factory reset without total data erase
Hello I have ready nas pro 6 with 6 discs: 1-2: Volume c in Raid 1 3-4: Volume d in Raid 1 5-6: Volume e in Raid 1 I don't know if this is possible: A) I remove discs 3,4,5 & 6 B) Back...
mdgm-ntgr
Aug 23, 2013NETGEAR Employee Retired
Why do you want to do a factory reset but keep your data?
No. The md device, volume group etc. would have the same name as for disks inside the NAS.
However if you connected the disk to an ordinary Linux PC you could mount the array easily.
pwarlike wrote:
if I take out one HD of the Readynas Pro and I connected it in the usb port of the Readynas, I can access the data from linux console?
