ihartley
Mar 16, 2013Tutor
ARM NV+ / Duo v2 CUPS print install USB printer
OK, I tried to install CUPS for printing on the ARM NV+ v2 , failed and had to do a factory reset. Second time around I was not so gung-ho, and at least it was done on a fresh install. You can follo...
bmayer
Jul 19, 2013Aspirant
Thank you all who are responsible for this very helpful info. I'm new to the NAS world, and thought I checked to be sure a Print Server was included in this device. This is key for me.
I have (I think) only one question. I'm fairly technical (I'm not intimidated by these instructions), but not so technical anymore that I understand all the details in your instructions. I'm not a programmer.
My question: Where do I get the CUPS layer? Once I install the SSH (which I know how to do), is the CUPS just configuration, or is it another layer of software that I need to install from somewhere (and if so, where)?
Bottom line (2nd question): After I have installed the SSH, is the rest just configuration or added software?
Oh yea, 3rd question: finally, once I successfully install/config this, will it be easy to install/see my printer?
Thank you!
Ben
Thank you!
Ben
