ihartley
Mar 16, 2013Tutor
ARM NV+ / Duo v2 CUPS print install USB printer
OK, I tried to install CUPS for printing on the ARM NV+ v2 , failed and had to do a factory reset. Second time around I was not so gung-ho, and at least it was done on a fresh install. You can follo...
necoboss
Mar 10, 2015Aspirant
Hi all,
I tried this on my readynas duo v2 and unfortunately something went wrong because now I have cups that seems to be working (at least I have access to mynas:631) but I have no access to frontview and my shares/DLNA...
I have ssh access still working but I'm not sure why I can't access my data stored in the disk.
I probably need to do a factory default reboot process (unless you guys have another solution :D )
I know how to mount a disk but I never played with RAID1 stuff and I don't want to break anything because I want absolutely to save my data stored on the HDD first.
Any help is pretty much appreciated.
What I did:
apt-get update
apt-get install cups libcups2
apt-get -f install
dpkg -i --force-overwrite /var/cache/apt/archives/libcups2_1.4.4-7+squeeze5_armel.deb
dpkg -i --force-overwrite /var/cache/apt/archives/cups-client_1.4.4-7+squeeze5_armel.deb
dpkg -i --force-overwrite /var/cache/apt/archives/cups_1.4.4-7+squeeze5_armel.deb
apt-get -f install
rm /etc/rc?.d/*cupsys
cupsctl --remote-admin
/etc/init.d/cups restart
apt-get -f install
apt-get autoremove
What I did:
apt-get update
apt-get -f install
apt-get -f install
apt-get -f install
apt-get autoremove
