ihartley
Mar 16, 2013Tutor
ARM NV+ / Duo v2 CUPS print install USB printer
OK, I tried to install CUPS for printing on the ARM NV+ v2 , failed and had to do a factory reset. Second time around I was not so gung-ho, and at least it was done on a fresh install. You can follo...
necoboss
Mar 23, 2015Aspirant
As I had no feed-back here I'm at least sharing what I found to mount my RAID 1 disks out of my readynas duo v2.
the key part is here:
modprobe dm-mod
vgchange -ay
termcb:~ # lvscan
ACTIVE '/dev/VolGroup00/LogVol00' [26.06 GB] inherit
ACTIVE '/dev/VolGroup00/LogVol01' [1.75 GB] inherit
mount /dev/VolGroup00/LogVol00 /mount/point
Source: http://pissedoffadmins.com/os/mount-unknown-filesystem-type-lvm2_member.html
It might help others...
By the way, did anyone succeed installing a printer/CUPS properly on 5.3.11 firmware without breaking everything else? I'm taking any tips/leads...
Cheers
PS: Another link that might help for RAID disks mounting: https://wiki.archlinux.org/index.php/LVM
modprobe dm-mod
vgchange -ay
termcb:~ # lvscan
Cheers
