Zeixxs
Jan 06, 2019Aspirant
Asking for help with "RAID level unknown" & "volume root is degraded" errors
Hello, After a firmware update, my Readynas 104 is unusable. I have the following error message: "Volume data RAID level unknown" (see capture). Diagnostics revealed that a disk has "pending sectors"...
Jan 07, 2019Guru - Experienced User
Zeixxs wrote:
when I start with 4 disks (exlcuding the one with pending sectors) I get "volume root is degraded".
I think you must mean 3 disks, since there are only four bays total in the RN104. Are you able to access your data when you boot the system this way?
To clarify - a "degraded volume" is one that is no longer protected by RAID redundancy, but which is still accessible. If you are seeing "corrupt root", then that is another matter.
- ZeixxsJan 07, 2019Aspirant
Hello and thank you for answering.
You're right, I meant 3 disks, sorry.
When I start with 4 disks I get the "disk 2 has pending sectors" and when I start with 3 disks (excluding the 2nd), I get "Volume root is degraded" and "md/raid:md127: failed to run raid set." when I use the diagnostic from RAIDAR.
I cannot access my data either with 3 or 4 disks.
I get to the 1st folder level (Videos, Pictures, ... but I click I get a network error message saying windows cannot access (error code 0x80070043).
