johnnyarias
Mar 29, 2018Follower
Auto mount and auto format ?
Hi, I'd like to know if the ReadyNAS is able to create 2 Volumes: First Volume made from 2 Hard drives in RAID 1 and Second Volume 2 Hard Drives in RAID 1.
What I want no know is if the Volume get's full will I be able to Hot Swap the RAID 1 pair, take the disks out and replace them with new empty ones, and the Ready NAS will automaticly format the two units in RAID 1 and mount them ?
1 Reply
- SandsharkSensei
In order to run two volumes like that, you need to be in FlexRAID mode. Once you are there, the ReadyNAS will not automatically do anything with new drives, but it gives you the option to do them.
I don't quite follow your sequence of events, so it's hard to say that it will let you do what you ask. If your sequence is that the NAS contains two 2-drive RAID1 volumes and you remove the drives of one volume and replace them with two more blank drives (for a total now of 6 drives), then you can create a new RAID1 from the two new drives.
But if I read between the lines and you intend to swap in and out the "retired" volume, that's not a good plan. The hardware's not designed for it.
