Lauri
Oct 12, 2015Aspirant
Automatisk avstängning av NAS 102
Jag har NAS 102. Problemet är att det inte går att programmera automatiska avstängning av NAS:en. Jag har prövat olika inställningar vad gäller Diskavstänging och Timer för ström. På min andra Rea...
Lauri
Google Translation
Automatic shutdown of the NAS 102
Options
2015-10-11 11:56 pm
I have the NAS 102. The problem is that it is not possible to program the automatic shutdown of the NAS.
I have tried different settings with respect Disk Power off and timer power.
On my second Ready NAS Duo v2 is not this problem.
Previously worked automatic shutdown of the NAS 102 as intended, but for updates and changes to settings, I have not received the automatic shutdown function.
- LauriOct 19, 2015Aspirant
As I wrote, that the automatic shut down do not function of my NAS-102.
I can not to program the time för current so that NAS-102 shall shut down at the programmed time.
The NAS-102 is on going whole time and I must shut down manually.
Before, in beginning the programming of that NAS were functioning, but after updating of NAS-102 i get that problem
Concerning my other the older Ready NAS Duo v2, have I none such problems.- JennCOct 20, 2015NETGEAR Employee Retired
Hello Lauri ,
Welcome to the community!
We apologize for having this problem after the update.
Please try turning off the NAS then turn it back on, then re-apply the power timer schedule then test again.
Please let us know if you get the same results.
- LauriOct 21, 2015Aspirant
Hi Jenn
Your advice did not help. I have have the same problem left after several turn offs, reprogramming and re-starting of of NAS-102.
But i do not have any such problems with my older Ready NAS Duo v2
Regards // Lauri
