Lauri
Oct 12, 2015Aspirant
Automatisk avstängning av NAS 102
Jag har NAS 102. Problemet är att det inte går att programmera automatiska avstängning av NAS:en. Jag har prövat olika inställningar vad gäller Diskavstänging och Timer för ström. På min andra Rea...
Lauri
Oct 19, 2015Aspirant
As I wrote, that the automatic shut down do not function of my NAS-102.
I can not to program the time för current so that NAS-102 shall shut down at the programmed time.
The NAS-102 is on going whole time and I must shut down manually.
Before, in beginning the programming of that NAS were functioning, but after updating of NAS-102 i get that problem
Concerning my other the older Ready NAS Duo v2, have I none such problems.
JennC
Oct 20, 2015NETGEAR Employee Retired
Hello Lauri ,
Welcome to the community!
We apologize for having this problem after the update.
Please try turning off the NAS then turn it back on, then re-apply the power timer schedule then test again.
Please let us know if you get the same results.
- LauriOct 21, 2015Aspirant
Hi Jenn
Your advice did not help. I have have the same problem left after several turn offs, reprogramming and re-starting of of NAS-102.
But i do not have any such problems with my older Ready NAS Duo v2
Regards // Lauri
