EstivalG
Mar 09, 2019Aspirant
Average transfer speed (read and write) plummeted after replacing hard drives
Hello everyone
TL;DR: I just replaced my 3TB hard drive with some brand new 8TB hard drive, and the average speed plummeted, from 70MB (switch 1)/100MB (switch 2) to a steady (but slow) 40MB on bot...
Anonymous
Mar 11, 2019Hi EstivalG , I can confirm the 40MB/s transfer speed. I get that from my retired RN104 with two volumes (RAID0 and RAID1), which I'm using as a guineapig for trying things out.
If you like you can try some hints in the below link and see, whether you can improve performance of your RN102 in general (In essence RN102 and RN104 do only differ in the number of bays they hold).
Should you find a way to boost the transfer speed back to 70MB/s using the more recent firmware releases, I will be more than happy to adopt your approach as soon as it will be available.
Kind regards
Mar 11, 2019Guru - Experienced User
I decided to benchmark my own RN102, and I discovered that my speed depends on the SMB protocol version. I tweaked the the max protocol with SMBPlus, and tested the results with NasTester 1.7. The measured read speeds are:
- SMB 1.0: 41 MB/sec
- SMB 2.1: 70 MB/sec
- SMB 3.1: 63 MB/sec
When I reported my 70 MB/sec results a couple of years back, I was still running Windows 7 (SMB 2.1) so the results haven't changed with newer firmware.
The drop off with SMB 3.1 isn't that surprising - I suspect Windows 10 is using transport encryption, and the RN102 has no hardware support for that.
The slow speed with SMB 1 was a bit surprising to me.
Test Details:
The RN102 is running 6.9.5, and the volume is XRAID (two 1 TB Ironwolf disks). Bit-Rot protection (CoW) is off on the share; Volume Quota is enabled. Strict sync is disabled, and SMB 3 transport encryption is set to "enabled". Antivirus is off. SMBPlus is the only app running on the NAS.
The PC is an older desktop running Windows 10; the PC is using 10 gigabit ethernet, but of course the NAS is using just gigabit. The PC hardrive is an SSD.
The NAStester results are:
SMB 1.0
Running a 400MB file write on \\10.0.0.13\Documents 5 times... Iteration 1: 39.43 MB/sec Iteration 2: 39.64 MB/sec Iteration 3: 40.24 MB/sec Iteration 4: 38.87 MB/sec Iteration 5: 39.67 MB/sec ----------------------------- Average (W): 39.57 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Documents 5 times... Iteration 1: 40.36 MB/sec Iteration 2: 40.71 MB/sec Iteration 3: 39.82 MB/sec Iteration 4: 41.65 MB/sec Iteration 5: 40.67 MB/sec ----------------------------- Average (R): 40.64 MB/sec
SMB 2.1
Running a 400MB file write on \\10.0.0.13\Documents 5 times... Iteration 1: 68.44 MB/sec Iteration 2: 67.45 MB/sec Iteration 3: 66.73 MB/sec Iteration 4: 66.87 MB/sec Iteration 5: 68.45 MB/sec ----------------------------- Average (W): 67.59 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Documents 5 times... Iteration 1: 75.39 MB/sec Iteration 2: 67.61 MB/sec Iteration 3: 67.51 MB/sec Iteration 4: 68.58 MB/sec Iteration 5: 69.27 MB/sec ----------------------------- Average (R): 69.67 MB/sec
SMB 3.1
Running a 400MB file write on \\10.0.0.13\Documents 5 times... Iteration 1: 69.35 MB/sec Iteration 2: 68.94 MB/sec Iteration 3: 69.08 MB/sec Iteration 4: 67.34 MB/sec Iteration 5: 69.00 MB/sec ----------------------------- Average (W): 68.74 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Documents 5 times... Iteration 1: 63.87 MB/sec Iteration 2: 63.06 MB/sec Iteration 3: 61.22 MB/sec Iteration 4: 63.89 MB/sec Iteration 5: 64.10 MB/sec ----------------------------- Average (R): 63.23 MB/sec
- AnonymousMar 11, 2019
Thanks for the detailed analysis, StephenB , very helpful.
