EstivalG
Mar 09, 2019Aspirant
Average transfer speed (read and write) plummeted after replacing hard drives
Hello everyone
TL;DR: I just replaced my 3TB hard drive with some brand new 8TB hard drive, and the average speed plummeted, from 70MB (switch 1)/100MB (switch 2) to a steady (but slow) 40MB on bot...
Mar 11, 2019Guru - Experienced User
Retired_Member wrote:
Hi EstivalG , I can confirm the 40MB/s transfer speed. I get that from my retired RN104 with two volumes (RAID0 and RAID1), which I'm using as a guineapig for trying things out.
I decided to benchmark my own RN102, and I discovered that my speed depends on the SMB protocol version. I tweaked the the max protocol with SMBPlus, and tested the results with NasTester 1.7. The measured read speeds are:
- SMB 1.0: 41 MB/sec
- SMB 2.1: 70 MB/sec
- SMB 3.1: 63 MB/sec
When I reported my 70 MB/sec results a couple of years back, I was still running Windows 7 (SMB 2.1) so the results haven't changed with newer firmware.
The drop off with SMB 3.1 isn't that surprising - I suspect Windows 10 is using transport encryption, and the RN102 has no hardware support for that.
The slow speed with SMB 1 was a bit surprising to me.
Test Details:
The RN102 is running 6.9.5, and the volume is XRAID (two 1 TB Ironwolf disks). Bit-Rot protection (CoW) is off on the share; Volume Quota is enabled. Strict sync is disabled, and SMB 3 transport encryption is set to "enabled". Antivirus is off. SMBPlus is the only app running on the NAS.
The PC is an older desktop running Windows 10; the PC is using 10 gigabit ethernet, but of course the NAS is using just gigabit. The PC hardrive is an SSD.
The NAStester results are:
SMB 1.0
Running a 400MB file write on \\10.0.0.13\Documents 5 times... Iteration 1: 39.43 MB/sec Iteration 2: 39.64 MB/sec Iteration 3: 40.24 MB/sec Iteration 4: 38.87 MB/sec Iteration 5: 39.67 MB/sec ----------------------------- Average (W): 39.57 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Documents 5 times... Iteration 1: 40.36 MB/sec Iteration 2: 40.71 MB/sec Iteration 3: 39.82 MB/sec Iteration 4: 41.65 MB/sec Iteration 5: 40.67 MB/sec ----------------------------- Average (R): 40.64 MB/sec
SMB 2.1
Running a 400MB file write on \\10.0.0.13\Documents 5 times... Iteration 1: 68.44 MB/sec Iteration 2: 67.45 MB/sec Iteration 3: 66.73 MB/sec Iteration 4: 66.87 MB/sec Iteration 5: 68.45 MB/sec ----------------------------- Average (W): 67.59 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Documents 5 times... Iteration 1: 75.39 MB/sec Iteration 2: 67.61 MB/sec Iteration 3: 67.51 MB/sec Iteration 4: 68.58 MB/sec Iteration 5: 69.27 MB/sec ----------------------------- Average (R): 69.67 MB/sec
SMB 3.1
Running a 400MB file write on \\10.0.0.13\Documents 5 times... Iteration 1: 69.35 MB/sec Iteration 2: 68.94 MB/sec Iteration 3: 69.08 MB/sec Iteration 4: 67.34 MB/sec Iteration 5: 69.00 MB/sec ----------------------------- Average (W): 68.74 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Documents 5 times... Iteration 1: 63.87 MB/sec Iteration 2: 63.06 MB/sec Iteration 3: 61.22 MB/sec Iteration 4: 63.89 MB/sec Iteration 5: 64.10 MB/sec ----------------------------- Average (R): 63.23 MB/sec
Retired_Member
Mar 11, 2019Thanks for the detailed analysis, StephenB , very helpful.
