h_tsopelas
Aug 25, 2015Aspirant
Back up problem
Hello, i have create 2 backup scheduled tasks for every Sunday. I press the start button today to take back up and the backup light of my ReadyNas 102 flashing. I try to open my server but now it doe...
Aug 25, 2015Guru - Experienced User
How much are you backing up? Is the backup to USB or a network resource? Or are you backing up to the NAS? What protocols are you using?
- h_tsopelasAug 25, 2015Aspirant
I take backup from my Desktop to the Readynas 102. It is about 30gb. I use Windows time because only with this protocol i can connect.
- StephenBAug 25, 2015Guru - Experienced User
Ok, backing up to the NAS using Windows timestamps. What was the source path?
How long was the NAS unresponsive?
Over 2 Hours! I use the settings:
Host: 192 168 2 2
Protocol: Windows/Nas Times...
Share: ARXEIA
At connection test it says that is ok! Also it says that the connection is ok with the protocol Windows Archive Bit. It is better this? Why i can not use the ather protocols? I try remote nfs but i take error
Unable to connect to host
Error code 7077010011
