connor25
Dec 01, 2015Tutor
Backup - Questions
Hi
Just to get my head around this when you backup directly to a External USB Drive, you got a number of options, one of them is schedule full backup weekly or two weekly etc?
I had set it ...
Sandshark
Dec 01, 2015Sensei
Make sure you check "Remove deleted files on target" on the Advanced tab so it deletes any files in the backup that have been deleted on the source.
- Sep 19, 2018Retired_Member
