johk
Sep 14, 2014Aspirant
Backup capability btw Readynas Duo NV+ v2 and RN10200-100AJ
Hi, Currently I backing up my Readynas Duo NV+ v2 to 2 separate usb drives. I am considering purchasing a RN10200-100AJS to do my backups to. Can I use rsync btw Duo NV+ and the RN10200? Also, ...
Sep 15, 2014Guru - Experienced User
You can, and I do. My RN102 is used for backup from my OS4 system.
johk wrote: Thanks guys,
The reason I ask is that I read somewhere that you can't use rsync btw an older version of readynas and a newer ( in this case the newer was Duo NV+ v2 ).
Johk
