jc2010
Jan 28, 2011Aspirant
Backup Connection Error
I'm trying to backup my PC (Windows Vista, 64-bit) using Frontview. The PC and ReadyNAS are both on my local home network, and I don't have a login/password on my computer. I've selected "Remote: Wi...
jc2010
Mar 13, 2011Aspirant
Hi ewok,
Thank you for trying ... but unfortunately, that's not it either. I can connect to her computer through mine with no problem. At first I thought it was because her user ID was two words (first and last name - not sure that happened, and am having a bear of a time changing it to a single word). But I've tried adding a new account to her computer (just calling it "owner") and logging in that way. Still it fails. My daughter also has a laptop running XP, and I'm having the same issue there. Her login is only one word, and I can access it just fine from my computer, but the ReadyNAS fails every time it tries to access it.
I have all three computers set up in Frontview in exactly the same way (IP address for the host, "C$" for the path, and the appropriate login/password for each system). Why would one work great, yet the other two fail every time?
