jc2010
Jan 28, 2011Aspirant
Backup Connection Error
I'm trying to backup my PC (Windows Vista, 64-bit) using Frontview. The PC and ReadyNAS are both on my local home network, and I don't have a login/password on my computer. I've selected "Remote: Wi...
lockvkf
Mar 20, 2011Aspirant
@ewok, in reply to Mar14 3:19pm post...
I connected to my Win7 laptop from a XP Pro machine fine over my home Lan wirelessly (supplying my Win7 user/pwd).
When I run the job as suggested, it runs successfully! I then test the connection (of the successfully completely job) and again it errors with the same error message I have posted here.
It seems the test connection doesn't work. It did use to work, at least under XP and Vista.
