jc2010
Jan 28, 2011Aspirant
Backup Connection Error
I'm trying to backup my PC (Windows Vista, 64-bit) using Frontview. The PC and ReadyNAS are both on my local home network, and I don't have a login/password on my computer. I've selected "Remote: Wi...
ewok
Apr 11, 2011NETGEAR Expert
It would need to be shared if the path you entered is to work. Otherwise, you can share the documents folder at the end of the path and use that as the backup source.
